How to install front fan in Cooler Master Elite 311 cabinet ?
vindicated
46
I was wondering whether I have to remove front panel of cabinet to install fan or install the fan from inside of case.
I see no way to remove the front panel(which the according to the manual of cabinet is the way to install front fan)and installing the front fan from inside of case seems impossible.
So can someone please tell me what to do before i break something?
I needed to remove front panel so as to tighten the fan screws from front side while placing the fan at inside of case.
The video guided me how to remove front panel.
Also had to remove Dvd writer first to remove the panel.
