I have looked at the top and it looks like I cant mount it to the top because there are no holes for screws.
Case model IG-MAX F5507 600W
View: https://imgur.com/Dkf92fa
if you could cable manage it probably it could fit a 240mm/360mm radiator on the front panel, not very sure but clearance is the one you need to put an AIO with 240mm~360mm range. Usually Tower cooler is sufficient if you do not plan on getting to overclocking or if your temps are nowhere more than 80c.I have looked at the top and it looks like I cant mount it to the top because there are no holes for screws.
But how would i fixed it to the top,can I use super glue?if you could cable manage it probably it could fit a 240mm/360mm radiator on the front panel, not very sure but clearance is the one you need to put an AIO with 240mm~360mm range. Usually Tower cooler is sufficient if you do not plan on getting to overclocking or if your temps are nowhere more than 80c.
There do not appear to be any ventilation exhaust openings in your picture of the top. Therefore it cannot be used to mount a cooler. There would need to be a grill similar to the one on the front and back of the case. The picture shows that the top is solid. If there is a removable panel in the top you would need to remove it so that air can exhaust from the top.But how would i fixed it to the top,can I use super glue?
