How to know if my pc parts will fit together
AfikH
49
Hello,
I've built gaming pc spec and i'd like to know if the parts that i pick will fit together.
Is there any site that can do this?
If not here is the spec that i've built :
Case : CoolerMaster Force 500
Power Supply : ANTEC AN2-V500 VP500PC GB 500W
Motherboard : Gigabyte GA-H110M-S2V LGA1151
CPU : Intel Pentium Dual Core G4400 / 1151 Tray
CPU Cooler : Arctic Cooling Alpine 20 PLUS CO
Graphics Card : Gigabyte GeForce GTX 960 GV-N960WF2OC-2GD
Ram Memory : Corsair Vengeance 4GB DDR3 1600Mhz CL9
HDD : Western Digital Caviar Blue 500GB WD5000AAKX
DVD Drive : LG GH24NSD1
Also if there is somthing missing,
or a part in the pc which slow down my pc i'd like to know.
Thanks in advanced, AfikH .
They fit, but a few problems here and there.
You don't need a CPU Cooler, the one in the box is enough.
You need at least 8GB of RAM, 4GB is not gonna be enough. And your selected RAM is DDR3, you need DDR4 for that motherboard.
If you want a real gaming quality PC, you need i3-6100.
Your GPU is old, better and cheaper choice is RX460, same performance(and better in Vulkan), lower price.
That PSU is not very good, get Seasonic S12II 620W.
Next time you want to check for compatibility issues, go to PCPartPicker.com and add all the parts you want.
If you can't find a piece of hardware, it's because it isn't compatible, there is a checkbox to disable compatibility check
That's when you can see all parts.
lakimens
AfikH
49
Hay lakimens,
Thanks for replying,
I'm a little bit comfused
you said that my motherboard is DDR4 but in GIGABYTE Website it says DDR3/DDR3L
url : http://www.gigabyte.com/products/product-page.aspx?pid=5645#ov
I changed my spec after your comment
this is my new spec :
Power Supply : Still not sure
CPU : Intel Core i3 6100 3.7Ghz 3MB Cache s1151 - Box
Graphics Card : Sapphire Radeon RX 460 OC 2GB GDDR5 DVI HDMI DP PCI-E
Ram Memory : Corsair Vengeance 2x4GB DDR3 1600Mhz CL9
Regards, Afik.
Latest posts
