How to know if what is the problem with my system
jaguarac1
15
My PC Specs:
Asus M5A88-M AM3+ Motherboard
AMD Phenom II X4 960T
Sapphire HD 6770
Kingston HyperX 1600mHz 8gb
Hec Rapter 2 600W
My monitor just shut itself (just black screen not power off) when something happens with the electrical like switching on the lights of my room.. I don't know what is the exact problem is it the mobo? psu? or the graphics card? I checked the mobo and there is no capacitor leak..
my HWMonitor stats
http://i.imgur.com/gwJmIdm.png
you swapped out the 6770 with another card and it worked fine?
you uninstalled the drivers and pulled the card and it worked plugged into the motherboard?
now you say the keyboard doesn't work properly?
any way to circumvent the hybrid switch?
have you disabled the on board graphics from the BIOS?
are you running the 0402 BIOS?
I did try but it happen again this time it become more sensitive like turning on my printer on.. The screen goes black then a buzzing sound coming from speakers sounds like my systems hangs.
I did similar to that before. I replace my graphics card, test it and it works fine.. But I was wondering if my motherboard was affected, I did research about this problem and I saw that when your keyboard isn't responding like capslock button and the light don't lit up, the problem is the motherboard. I'm confused actually if the problem is the Motherboard, Graphics Card or the PSU
-yes
-yes that worked either
-no I mean when the monitor goes black under the 6770 card and hangs my computer later, my keyboard isn't responding according to the website I've read the issue there is the motherboard. Now I'm confuse if what is the problem with my computer
-I don't know how to
-I don't know that either sorry
