how to know wheather a graphics card is compatible for a motherboard
GEELU605
39
do amd radeon r9 280 sapphire dual-x oc 3gb run properly on
core i5-3470@3.2GHz-processor
gigabyte ga-b75M-d3h-motherboard???
and is that graphics card overclocked by manufacturer
thanks in advance
It should run on your PC, and yes it is factory overclocked by the manufacturer; however you can overclock further.
I'm pretty sure there won't be a bottleneck. You need to make sure you have at least a 500w power supply, or 850w if you're going to have a crossfire setup.
