How to Launch Crysis on a 64 bit Operating System On Steam
snickersniff
112
Hello,
If you have a 64 bit system and have purchased Crysis you probably know the pain of hitting play and Crysis crashing. I am here to tell you a fix for that problem!
1. Go to this link http://dl.dropbox.com/u/71527378/Bin64.zip (I scanned it with bitdefender it is a safe file)
2. Save the File to your desktop
3. Now unzip/extract the zipped folder to your desktop
4. Now the folder you just extracted that is called Bin64 drag that into the following, Steam\steamapps\common\Crysis
5. Now you must read this carefully because this is the most important part, rename the Bin32 file to Bin32.bak
6. Now rename the Bin64 file you downloaded to Bin32
There you have it! This fixes the problem most of the time but if Crysis still crashes you can try the following. Turn off your anti-virus software while you try the game, if that stops the crashing, you need to add the game to your AV exceptions. Again not for everyone, but that should work for most people.
I hope this helps!
Moderator Note: If you wish to take a chance and get the previously linked file, PM the OP.
Please do not link to the file again. Communicate the info with interested users via PM. Downloading files from unverified sources is a good way to infect a system.
