How To
How To Level Fast In Deus Ex: Mankind Divided
Looking to get those praxis points you need to finish upgrading your favorite most used augment, but not sure how best to go about earning the experience you need to do so? There's a few different ways to earn experience in Deus Ex: Mankind Divided, so let's go over some of the quicker options to get some bonus experience.
Step 1)Get through a mission without alerting anyone
This is probably the biggest boost of experience you can get, but it is going to require some careful stealth, and possibly a few reloads, to accomplish on most missions. You can still perform take downs on guards as you go and get this, you just have to not be seen while doing it.
Step 2)Explore often.
You will be awarded both for the exploration itself, and for finding alternate paths if they are available. This isn't breach mode, and you don't have a time limit, so take your time, look around, and you might find an interesting way to solve an otherwise difficult problem you come up against.
Step 3)Hack everything.
Even if you have the password for that terminal.. Why not just hack into it? You'll get experience for the hacking where you wouldn't if you used the password, so it's definitely worth it to spend some time and Praxis points on your hacking augments, they'll lead to more Praxis points in the future.
Step 4)Side missions, side missions, and more side missions.
These are the most important for leveling up, Almost every side mission is going to force you to explore, hack things, and grants it's own experience when you finish it. It's an all around win completing these to level up as quickly as possible. If a mission has a side objective you can complete, do that too for some more experience for each mission.
Hopefully these tips help you to get as many of those Praxis points as you can. Keep in mind as well, you can buy them too if you manage to collect enough credits!
