How to make Mic pick up piano sound
alex.trissia
4
I would like the mic of my Razer Kraken Pro V2 to pick up, not only the sound of my voice but also the sound of my piano/keyboard. Not only to record but also in conversations like on skype etc. Is there a good way to turn down the general sensitivity or something so my keyboard/piano is audible?
If youre going to do something you should try to do it right. The Kraken mic simply isnt up to the task because its designed to isolate your voice from the surroundings.
