Hi All,
I've cut down some heatsinks and I peeled one half of the thermal pad strip and placed it along the VRM's, then I peeled the other side off the thermal pad and placed the Heatsinks on top (before popping the heat sinks on top I applied pressure alog the thermal strip to bed in). But the adhesive pad does not stick at all, I have to be careful because there's components behind and in front and if that heat sink moves much it may bridge a connection.
Update
So after some inspiration from Nukemaster, this is the masterpiece I constructed all from an Age 6 construction kit and two motherboard offset screws.
Update
