How to match cpu to memory speed
Steve_93
I'm looking to build a new computer and would like to know how to match CPU speed to memory speed. To get the best performance the speeds should be matched. Mismatching just waste money and performance. Now that there is so many new things there is a lot to learn. I'm looking at AMD Phenom CPUs and DDR2 & DDR3 memory, but the speed of each doesn't indicate which should be used together. Anybody have any imformation on how to match these items? Thank you, Steve
tubers
92
oh same here.. my uncle kept telling that there is a "matching" rule about RAM speeds and CPU speeds.. and if not matched is a total waste...
ive never heard of that before..
i own a Phenom 9950 @ 2.6 Ghz and have a RAM of DDR2 800Mhz that can go to 1066Mhz.. are these matched?
The rule was for Intel LGA 775 builds.
For AMD, you just need DDR2 1066 or DDR3 1333. Anything faster than that is wasted with the current memory controller.
That's not to say you shouldn't buy 1600Mhz DDR3 now if the price is right. DDR3 will be around for a while and maybe some future build will make better use of faster RAM.
It's ALWAYS a good idea to get the lowest timings and lowest voltage you can at those speeds however.
tubers
92
uhm i pretty much didnt get it..
what i only know is
Phenom AM2+ only supports DDR2 up to 1066 Mhz.. DDR3 is reserved for AM3 CPUs..
uhm anyway is there some kind of rule like this
phenom 1 x4 9950 @ 2.6 Ghz = use DDR2 RAM 1066Mhz to match the CPUs speed
phenom 2 x4 940 @ 3.0 Ghz = use DDR2 RAM 1333Mhz (example only)
Athlon x2 7750 @ 2.7 Ghz = use DDR 2 800Mhz to again.. match the CPU speed..
is there some kinda rule like that? (i was just making examples to further explain my problem)
(thanks for the quick reply tho)
oh and could u please explain to me the LGA 775 memory matching rule? does it also apply to the core i-7s?
Stop making it more complicated than it needs to be :)
There is no speed matching needed with AMD CPUs. Get either DDR2 1066 or DDR3 1333 (or higher if you like, but it won't make the computer faster).
Older AMD CPUs only use DDR2. The newest AMD CPUs use either DDR2 OR DDR3. For those, like the X4 955, there is no real speed difference between the two memory types. You can use either DDR2 1066 or DDR3 1333 and get the same results.
With LGA 775, the "ideal" memory speed is tied to the FSB x 2. So if the Front Side Bus (FSB) is set to 333Mhz, like it is with a Q9550 for instance, then all you need is 667Mhz RAM (333 x 2). Now, 800Mhz RAM is pretty cheap, so just go ahead and buy that and run it at 667. Won't hurt anything.
Now, if you plan on overclocking that Q9550 a lot and raising the FSB to 420Mhz, the you will need memory that can operate at at least 840Mhz, so you might want to buy 1066Mhz RAM.
