[SOLVED] How to mirror drive onto partition
RoccatKanga
40
Hello,
This is my storage setup:
1x SSD --> runs Windows 10 and most files
2x HDD comfigured with RAID--> backups of Phone / Games / other stuff
I want the SSD to be Cloned onto the RAID alongside the other files into a folder, should the SSD die.
Is that possible?
I hope this isn't addressed yet in the forum
You would've had to do this right when you first setup the raid array to make it bootable.
As mentioned, store an image of the drive on the HDD and use the same utility to put it back on the replacement SSD should you ever need to.
Many of us use Macrium Reflect free. It will even create the bootable flash drive for you.
