I am building a machine learning server on a WRX90E-SAGE motherboard, with dual Gigabyte OC RTX 4090s, which I want to go in the green marked PCIe slots as shown in the image below. I am using a Fractal Meshify 2XL case.
But the instructions for the GPU anti-sag mounting brackets are assuming that there is a single GPU, and there is no way to mount two of them.
The instructions also are assuming the mount points for an ATX motherboard as opposed to the EEB motherboard. The two bottom right screws (circled red in photo) which the instructions say is where to install the mount bracket, are in a different location from the standard ATX board position. So even if I put in a mounting bracket for the top card, it likely won’t be in the right place. …
I’m not sure what to do here, short of 3D printing my own custom brackets. I’m wondering if anyone here happens to have mounted dual 4090s on this board, and how you did it?
