[SOLVED] How to mount radiator fans?
Nov 29, 2017
15
Alright. Should I have the fans on the radiator mounted so they are visible or not? Really confused.
The radiator is mounted in the front.
It’s a Corsair Hydro H100x.
It doesnt matter which side of the rad the fans are mounted to.
It doesnt really matter which way the blow air either, however most people have them sucking cool air front the front of the case then have an exhaust fan at the rear of the case to expel the warm air.
No it doesn't.
Of course the added benefit of you having them on the inside is if for any reason you need to change/clean them, they are easier to get to.
Okay, great. Just one final question, do the cables route like normal or do I have to change anything about that?
The way the cables work will be unaffected but the radiator orientation
