I. too. prefer to have slightly more intake capacity than exhaust, producing a SMALL "positive pressure" condition inside the case. That MUST include dust filters on all the intake fans, AND preiodic inspection and cleaning of those filters. That way at any small air leakage points in the case, air flow will be OUTWARDS and prevent intake of dust.
Doing that in the design phase by adding up air flow capacities of all the fans is a VERY rough starting point and will NOT guarantee you will achieve positive pressure. Both the dust filters and the AIO system radiators impose significant reductions of air flow from what the fan specs indicate, and this affects the intake fans more than exhaust. But once you have the system in operation you can test for the REAL conditions easily, and maybe make an adjustment if you see the need. You need a small source of tracer "smoke", like a smouldering cigarette or a stick of incense. Slowly move that smoke source around the outside of the case near any possible small leakage point, and watch the smoke direction. If it flows VERY fast you may have too large a difference in air flows, but that often is not so important. Mainly, if the smoke flows AWAY from the case, you have it right. If the smoke goes INTO the case, you need to fix that. I suggest you do this before decideing whether to replace or adjust any fans. As a final test point, repeat the test at several workloads, in case high workload causes a different fan airflow balance.
