How to partion hard drive for best performance
mbill
6
I want to know how to partition a hard drive for maximum performance. Is there a way to partition a drive to use only the fastest outer rim of the drive? I would like to get 3 of the new western digital 750gig HD WD7500AAKS drives and partition them from 100 to 400 gigs.
As a secondary question it’s my understanding that windows XP can only support 1.5 tera bytes. So this is another reason I want to partition so I can use 3 of these drives. If I only make active the partion on each drive that I want to use, is this all windows XP will count. Or will it try to add up 3 times 750 gigs.
Mbill
chookman
3,319
This is a little back to front to understand ... are you RAIDing these drives? if so wat raid and how.
The fastest part of a drive is the inner track and this will be used when creating the first partition. Any subsequent partitions slowly make there way to the slower outter section of the disk.
mbill
6
No i am not raiding these drives. I want 1 drive for windows XP, 1 drive for applications, and 1 drive for downloads. I may add 1 drive later for other purposes.
mbill
englandr753
2,634
78
What else are you putting on the hard drive that has the OS installed? 750G is a sinful waste for just loading an OS. If your not going raid then get a 74g or 150g western digital raptor hard drive. It will be much faster than the 750G hard drive and will still have some extra room for a few minute things you may want to install later without being overkill...
mbill
6
Yes i came to the same conclusion that the windows hard drive could be a 74 gig raptor. I have a similer setup now and i am only using 15 gigs. The 3 harddrive setup i have now is setup as i describbed but with slower IDE hard drives.
But my application drive is 200 gigs and i only have 30 gigs left. my download drive is 300 gigs and it is full. A 150 gig raptor is to small for either of these jobs. So i am trying to find a fast hard drive in the 300 to 400 gig range for applications and downloads.
mbill
kolix
56
um, from my understanding, it is better to have one partition on each single hard drive, performance wise for non-raid
and if you are very picky, you can create a smaller partition on a single hard drive to leave out the outer sections of the hdd (but I suspect performance gains to be close to nothing)
and if money is not a problem to you, then get ram drives or those solid disk drives / flash memory drives
(edit: I meant solid state hard disk drives or however you call them, not those USB flash disk drives)
furthermore, if you are the risky type, you can tweak your OS for disk performance
you can research up disk allocation unit size, caching, defragmentation, etcetera
close to subject, google up "7 max" if you are _really_ _risky_ and are a windows user
chookman
3,319
My suggestion would be
74gb Raptor for OS
500-750gb for Applications
500-750gb for Downloads...
The OS drive you could partition further say 50gb OS then rest for page file but i think that would be a waste... one 74gb partition will be fine.
As for the rest you can prolly leave as a single lump partition.
Windows XP will not hit any kind of limit with parition size here as i believe its 2tb and this doesnt stack with number of partitions/disks.
mbill
6
Ok here are my latest realistic thoughts.
1 pc WD740ADFD for winXP.
2 pc samsung spinpoint T166 HD321KJ sata300 320gig 16meg cache, for application drive and download drive.
mbill
SomeJoe7777
1,081
Just so we're all clear, the fastest portion of any hard disk is the outer track, not the inner track. Hard disks will also allocate partitions from the outside first, and move inwards with additional partitions.
The trick of taking a large hard drive and partitioning it such that a small partition is the only thing on it and uses only the outer, faster tracks is called short-stroking.
The partition's STR is quite fast because only the outer tracks are used, and the access times for that partition go down as well, because the head is only moving over a shorter range of tracks instead of the whole platter.
This technique has been used in enterprise environments on SCSI/SAS drives to increase database performance, where in many cases speed of access is more important that storage capacity.
MooseMuffin
149
I'm a little confused about putting the OS and your applications on 2 different partitions. Splitting off downloads makes sense, since you can wipe your OS partition and still have all your stuff. Thats not true for installed applications though is it? If I have to wipe my OS and install a fresh one, its not going to know about those apps is it? Or is this strictly for performance benefit?
mbill
6
"Just so we're all clear, the fastest portion of any hard disk is the outer track, not the inner track. Hard disks will also allocate partitions from the outside first, and move inwards with additional partitions.
The trick of taking a large hard drive and partitioning it such that a small partition is the only thing on it and uses only the outer, faster tracks is called short-stroking. "
Thank you for that reply. That was the orignal information i was looking for.
mbill
pip_seeker
437
Hmm, this sounds interesting... but of course I can't see any real benefit as I can't find any benches on this.
I wonder if TOMS can look into this and post some benches of setting up drives in this manner and see if we could get some real world performance numbers.
It seems kinda slow around here and I think this little exercise would be a good one. So what do you say THG? :sol:
shine
25
Performance? NTFS filesystem is so limited.
You will get performance if you make a partition (in your OS HD or better in another HD), for your swap (pagefile) of about 2x(RAM size) [Gb].
And your windows' ntfs filesystem will fragment slower.
kolix
56
to pip_seeker:
it should be faster, also depends on amount of platters, platter density, and how much of the platter you are using
so the more you limit the platter area, the faster the performance albeit marginal
and somejoe7777 is correct, it is the outer portion of the platter, not the inner portion that I have earlier mentioned
and since there is less storage space to consider after limiting the platter area, you can use FAT32 on WinXP opposed to NTFS to squeeze that extra tiny amount of disk performance (unless you need the features of NTFS)
G
Guest
Guest
OMG are you trying to tell him to use FAT32, that is nuts. Fragmentation here I come. DONT use FAT32. Use NTFS even if you don't use the security features of it. The ONLY time I would ever use FAT32 in a computer or on a hard drive is if you needed to read/write from a linux PC to that hard drive also.
PS even after countless benchmarks it is usually a good idea and I WOULD stick to it... keep your Page file on your OS drive. You will not see a performance gain from putting it on a 2nd drive. Especially since your programs will be running from a 2nd drive, it would actually be better to keep it on the OS drive.
Also, if you have more than 2G of ram just make your page file 1024MB static and dont let windows resize or take care of it. Making your Pagefile double your RAM was waaaay back in the day if systems with 16MB-512MB ram. Windows is stupid to even try to suggest making it bigger.
Also another little tip is when you are defraging your OS drive, delete your Pagefile then defrag, and then recreate your pagefile again. This will give you the best defrag you can get on that drive.
pip_seeker
437
Well thanks gize for all the suggestions, but I really would like to see THG set up some tests with some large drives like 250GB+
Testing a regular drive with no partitions and one with partitions. We get this all the time on these boards with people who partition the hell out of their drives. So I think it would be a very good interesting article... as only THG can deliver.
I've been computing for a long time and back in the day when hard drives were sub 30GB IDE UDMA66/100 etc and so forth, it was a rule that partitioning actually decreased performance.
But I've actually done some searching here lately on this subject and am now finding that there are alot of sites recommending to partition.
Personally for me it makes no sense, as I have a good way of backing up my data and my drives are plenty fast for what I need them to do.
For me to make partitions on a drive would just compound the task of backing up the data and trying to remember which drive my stuff is on.
I even remember articles in yrs past here on THG where they took a promise ide controller card and did a mod on it to make it perform as a raid controller. Not sure if any of you here remember that, it's probably still here somewhere if you look for it.
I fully understand the idea behind partitioning to make the system use the outer edge of the disk for faster performance. But what I would like to know is EXACTLY how much performance gain one would achieve in doing so.
The only way we will ever know for sure is a benchmark.
So THG, when you get some free time... how about it???
nhobo
561
Partition is primairly for organizing data, not for performance. Raptors are waaay overpriced and not appreciably faster than new SATA drives.
kolix
56
to thecompukid:
personally, I don't think it is dangerous to run WinXP on small capacity drives using FAT32
I also believe FAT32 has the potential over NTFS in disk performance, even if it is hardly noticeable
yes, I acknowledge the benefits of NTFS over FAT32 (check the wiki) but each has their own use
in my previous post, I stated FAT32 can achieve a tiny extra amount of disk performance over NTFS in a more confined storage area (implying a few GBs)
you also have good tips about the pagefile but setting the pagefile limit to ~1GB is not enough for some people
(sometimes, I need the pagefile to be > 1GB since I have worked with > 1GB files in hex editing)
runswindows95
2,715
147
How I would do it:
A 160GB For OS's and programs
A small, cheap drive for page file, downloads, scratch drive, and swap file
A big one for all my data.
Also, it really doesn't make sense to install programs on a seperate hard drive considering when you wipe the OS, you will also uninstalling a lot of criticial files needed to run the programs.
Edit: Do not use FAT32 for anything other than for a page file partition or a small transfer section for Linux.
There's only about 6 current threads less than a month old on the topic. You can pick up the details in simple search but here's the short version.
1. Raptors are past their prime. They were kings in their day but have been surpassed in just about all benchmarks but access time by bigger, denser, quieter and cooler 7200 rpm drives. For gaming or high end windows, they just don't sit on the top of the hill anymore.
2. Typically, a HD is twice as fast at the outer edge as it is at the inner edge. There's no arguing that 80Mb/s versus 40 Mb/s isn't a big difference. Being able to put stuff on the outer edge that you want to go fast like page / temp files and games is big.
My son has two partitions that he uses for games. Every game gets installed to E:\ which runs from about the 20 GB mark to the 52 GB mark on his 250 GB drive. When he is done with a game for a while, he cuts / pastes the game from E:\ to F:\ It won't run from there but he just "stores" it there until when / if he gets the urge to play it again. he gets tired of something else, he moves it off to F:\ and copies something from F:\ back to E:\ that he fells like jumping into again. he has a lot of flight sims and they take long to load and he finds that having them on the 75 Mb/s part of the drive is better than having them on the 45 MB/s part of the drive. His page file is on the outer edge of his 2nd drive, the rest of drive 2 comprising his music and video collections.
3. FAT32 has a distinct advantage if you have a small partition for temp and page files. NTFS file protections are pretty worthless on temporary files anyway so no risk there. Stick with NTFS for everything else.
4. Rotational speed and DTR aren't the only advantages to partitions.....smaller MFT's and shorter seek times are another benefit.
5. Partitioning in and of itself doesn't give the advantage so much as what and how you put on those partitions.
6. If you are really spending a lot of time thinking about this, and thinking of RAID and 3 or 4 drives, then 15k SCSI drives (135 MB/s DTR) should also be a consideration.
kolix
56
to supremelaw:
very nicely said about FAT32
now, if I only have the spare time to change all my USB flash drives, ram drives, and floppies from FAT to NTFS
(my linux distros don't use either so I'm good with them)
P0110X
8
1. a first partition for swap file, since the first part of any disk is almost 40% faster than the last part.
2. a partition for OS
3. data
gunnar123
A benchmark program that illustrate the "faster on outer cylinders" effect is HD Tune. It plots a diagram from 0 to 100 % address range that for rotating platter drives show a declining curve as we approach the end of the address range.
Typically we are at 50 % of speed there.
This is easy to understand since the speed at which magnetic media pass under the read/write heads increase with the radial distance from platter center. Data can be transported onto or from disk ater a higher speed, effectively stored using about the same density all over the medium.
Similar threads
