How to "Permanent-On" LED Fans of CM Storm Scout 2 Advance
jpmeneses21
119
I have a pair of stock LED fans that came with my CM Storm Scout 2 that I'm not using anymore. I'll be giving these to a friend who needs additional fans, but the problem is, the fans came with two cables. 1x 3-pin, and the other is a 2-pin male connector for the LED Switch function of the Storm Scout 2.
The problem is, the fan won't light up if only the standard 3-pin is connected (because my friend's case doesn't have an LED switch). Is there are a way to make the LEDs work (permanently) via the 3-pin only?
