how to place motherboard standoff screws
rcbaker89
17
I'm building my first pc and when reading the instructions its telling me to install the standoff screws that came with the case. There is 9 holes that line up between both the atx motherboard and the case and there is 3 smaller holes (2 in the middle close to each other and one that is by itself near the rear fan), these don't line up with the motherboard, is that where I would need to place these stand offs? Also should I install the cpu before or after when trying to place the motherboard into the case.
these are white plastic standoffs with a flat circular surface abotu the size of a dime/penny that pegs into something. I finally found a youtube vid that helped. put the gold screws into the case and then use the black screws to screw into those. :)
those plastic ones are confusing me though.
