how to plug asus r9 280 to power supply unit vs 650 with connector?
spi_ajay
405
hello,
i have r9 280 asus graphics card. and i have got connector , i have a confusion coz one connector get connected to graphics card and it has two ends with 6pin . should i connect both to psu 6pin each ?
Your PSU should have two or four spots for GPU power connectors. They will be labeled on the PSU or in the manual. Could you link the PSU I might be able to see if I can get a picture.
http://www.corsair.com/en/vs-seriestm-vs650-650-watt-power-supply
this is the one i have , help me please it has two 8pin connectors in psu . should i connect both to this one single gpu (coz gpu's other end has 2 6pin connector which can be connected to psu)
Do you have the 24 pin connected to the motherboard? What about the 4/8 pin connected to the CPU? Tell me what you have left. To me the pictured looked like that PSU only has one PCIE 6 pin power connector.
yes i connected 6pin (2nos of gpu coming from same point from gpu end ) for both of the 6+2 of psu . should i connected to only one 6+2 of psu or both ?
He can't use one connecter for two connections. If he uses the one 6+2 for the 8 pin connection he still needs a 6 pin connector.
So your PSU has two 6+2 pin connectors?
Look like extensions. What does the other side of the connection look like?
I'm guessing your PSU only has one cable left for you're GPU, which is the 6 + 2 pin connector. The connector you have connects to molex, and are less reliable than the actual connections. So I would recommend a different PSU.
molex.? i donno what u said ? just help me with what i already got vs650
Basically you're PSU doesn't have enough power connectors for the GPU.
That connector looks like it has two six pins on the back, but would be plugged into a modular PSU. Like I said you're PSU doesn't have enough connections. You need a PSU that has one 6 pin, and one 8 pin or 6 + 2 pin connector.
my psu has 2nos of 6+2 in psu . but both can be connected to gpu . as gpu connectors has 6pin 2nos . i will connect them to 6+2 of psu . is it ok?
