Question How to plug front panel ports into a Nitro N50-600 motherboard?
Aug 11, 2019
18
Hey there. I recently bought an Acer Nitro N50-600 and I want to change the case. However some problems about the motherboard and front panel ports arose.
The case I have my eyes on is the Fractal Design Meshify C since it has absolutely everything I'm looking for and would fit my components wonderfully. On the front panel, two USB 3.0 ports are to be plugged into the motherboard with a female 20-pin USB3 connector. However, the Nitro N50-600 motherboard does not feature the required male port. Furthermore, I'm confused as to where I'm supposed to connect the other front panel ports. Any suggestions on how I could plug everything? Is changing the motherboard the only option?
The motherboard is a Nitro N50-600 by Acer Inc.
I included a picture showing the front panel, the corresponding cables and where to plug them. See this page for the image's source.
