how to plug psu cable in ups ??
rajivpao
80
Hello friends I need your help..
My psu 3 pin 13a cable does not fit into thoe 3 pin socket of my ups. How can I put it ??
Sorryy.. actually iam new in this forum.. and I don't know how to post pics in this forum.... 🙁 but I can tell you..
My ups 3 pin socket I in circle position and the psu 3 pin cable is somthing like rectangle shape
Ups model is elnova t- 640
Psu is corsair vs 550 watt
That cable is for the UK.
Go to a computer store and buy a power cord. That power cord will fit in your UPS.
I have bought a Corsair CX430 and that also came in with its own power cord. I didn't use that.
As for posting pictures: go to imgur.com and upload your picture on the website
They'll give you a link, such as imgur.com/abcdef
then use [ img][/img] tag and post link inside that.
e.g
The link to the above image is:http://i.imgur.com/8emhYl6.png
I don't know that. I'm from India as well.
If you have an old computer then you can use its power cord. They're compatible.
The power cord doesn't need to be exactly the same. It just needs to have that plug which will fit with the plug on the power supply.
