how to power lcd in AiO build
Sep 27, 2018
Can i Safely plug a 5v lcd (2x2pin) power cable into a (4pin) system fan header? Can/Should I connect it to the psu directly? Will this kill the display?
SYS_Fan header has adjustable 12v power so it may burn your LCD, also only 2 pins are power, one speed sense and 4th is PWM adjustment, so no you can't do that. Better connect to to PSU's Molex connector Black (-) and Red (+), Yellow gives 12vdc.
Thank you, your answer is perfect & really helps me narrow down on a new psu.
