okronk, does this problem present itself in other ports? If it does, then the drive needs to be changed. As for connecting the drive to the lid of the laptop sounds like you been playing too much Fallout. Not a good idea as it could detach itself and fall thus damaging your drive even further. Would not be a a bad idea either to back up your information just in case.
Basically you want:
3 copies of any data you don't want to lose
2 different mediums it's stored on (so 2 different drives in your computer, for example)
1 copy kept offsite, to prevent against disaster.
Best of luck.
