R RicEcho Prominent Jun 18, 2017 28 0 540 Aug 15, 2017 #1 Hi this may sound dumb but i don't know how to do this. My cpu fan is a water 3.0 riing rgb 360 but I don't know how to put water in it
Solution G G Gahl1k Aug 15, 2017 That is AIO liquid cooler, it requires nothing but installing it properly on your CPU. You don't need to add 'water.'
G Gahl1k Distinguished Aug 1, 2017 578 13 19,515 Aug 15, 2017 Solution #2 That is AIO liquid cooler, it requires nothing but installing it properly on your CPU. You don't need to add 'water.' Upvote 0 Downvote Solution
R RicEcho Prominent Jun 18, 2017 28 0 540 Aug 15, 2017 #3 Gahl1k : That is AIO liquid cooler, it requires nothing but installing it properly on your CPU. I thought it need water? Yes I know what kind of water Upvote 0 Downvote
G Gahl1k Distinguished Aug 1, 2017 578 13 19,515 Aug 15, 2017 #4 It's a closed All-In-One cooler, how are you going to disassemble it in order to add 'water'?!!!! Upvote 0 Downvote
n0ns3ns3 Illustrious May 25, 2016 8,065 4 42,715 Aug 15, 2017 #5 it does not need water. when the liquid inside evaporates, you through this crap to recycling. that might take few years. Upvote 0 Downvote
G Gahl1k Distinguished Aug 1, 2017 578 13 19,515 Aug 15, 2017 #6 n0ns3ns3 : it does not need water. when the liquid inside evaporates, you through this crap to recycling. that might take few years. Hahaha, and here is another reason why air cooling is better. Upvote 0 Downvote
n0ns3ns3 Illustrious May 25, 2016 8,065 4 42,715 Aug 15, 2017 #7 don't confuse Liquid Cooling with AiOs. later is just wannabe. a proper custom loop is way better than any air cooler if you don't mind the price. Upvote 0 Downvote
lumineZ Distinguished Jul 25, 2017 1,802 22 21,165 Aug 15, 2017 #8 I cant figure out why people still go with them AIO coolers... An high end air cooler do the same as an AIO... Wanna go water.. well go for an full custom loop, more expencive yes indeed, is it worth it? Price aside oooooh yes. Upvote 0 Downvote
