Hey Everyone,
I have some of questions.
I wanted to know when you recommend a power supply unit do you read benchmarks of watts used in a particular component? For example CPU uses 128W when overclocked, and the GPU uses 300W when on full load.
Or do you use the stated wattage by the manufacturer?
For example, at Intel.com they listed the i5-2500k for Max TDP of 95W. Or newegg states that a graphics card needs at least 500W.
Also, do you use a power supply unit for full system load or have some overhead?
For example, a fully customized system is rated for 500W. Do you buy the exact watts or give some overhead (525W) or go higher such as 600W?
Last question, is it better for the Power Supply Unit to be loaded at 50% of it's capacity versus 85% capacity? Will it decrease the life or performance of the PSU? (and no it's not about efficiency levels such 80 PLUS bronze, gold, etc)
Thanks for any replies
