How to remove dust filter on Thermaltake Commander MS-I case?
QuantumLord
Commendable
Mar 28, 2016
13
Hello. I bought 2 Corsair AF120 Quiet Edition LED fans 2 weeks ago. I installed one of it into the bottom of my case (unfiltered), and the other one to the front (filtered). However I noticed something after I installed it. While the bottom fan was blowing air, the front fan didn't! I placed my hand where they were supposed to blow air, I couldn't feel the front fan blowing any air in(although it as running at full speed/12V). I took out my front panel and blew as strong as I could, but I noticed that only a little bit of air was going in (roughly 25-30% of what it should be). So I plan to remove it and change it with another filter that doesn't restrict the airflow that much (maybe a homemade one such as a pantyhose etc.). Does anyone have knowledge about this case? Can I remove the dust filter? If I can't what should I do then? Any suggestion is welcome.
Maybe held on with magnets? Or it slides out. Or the case manufacturer has changed the laws of physics and generated a tiny gravity well that holds it on.
You should usually set your fans up to move air so that all intake air comes through a filter - in other words, the front fans are usually intake fans. In that case you often cannot feel the air movement on the intake side of a fan. While the air filter may *slightly* reduce the amount of air the fan can move, it will significantly reduce the amount of dust-build-up inside your case. Dust build-up affects cooling more than the slightly reduced airflow.
Thanks for the reply but I can't feel any air moving when I place my hand inside of the case too. I move my hand as close as possible (inside the case) to the front fan but still nothing. There is another fan placed at top as an intake fan too. I think the "pc-guy" who built my pc did that because of the horrible cable management he did. That is unfiltered too. Also I cannot change its direction because of the * screws he used.
1. Use a piece of tissue paper to determine the direction it is blowing.
2. Fans generally go:
In the front and bottom
Out the top and back
Thanks USAFRet. But I see that I couldn't express my problem very well. My problem isn't "the fan on the top that blows air in instead of taking the air out". It is: the dust filter in the front panel of the case blocks the airflow more than it should (I think). What can you suggest? Also I plan to remove and change it (if I can).
The top fan blowing in IS a problem. But we can address that later.
For the front filter restricting the airflow...that would have to be a pretty tight weave.
As mentioned, instead of your hand, use a piece of tissue paper to determine airflow. Direction and strength.
And a dust filter almost has to be removable. After all, how do you clean it when it gets dirty?
Well I tried that method and the tissue seems to move more when the front panel (w/ dust filter) is removed. Also I can't seem to find any screws that hold the filter in place, I see just an un-removable looking metal "frame" that holds the filter in place. I can add some pictures if you want. (Approx. 2 hours later)
The PC I'm typing on has an older Fractal Define case I picked up on a sale around 2013. The front duct filter on that is a real PITA. If I recall, it's actually screwed to the fan or some such issue
I just realized that there are little bend-able mesh clips that hold the dust filter and the mesh that is surrounding it.
I don't want to drift away from this tread's topic but I need help about that top fan. The hole where you put the screwdriver's "head" on the screws that hold the fan in place are "washed away" I mean it's literally like a hole that makes screwing the screw impossible. So I can't change it's direction.
For a stripped screw:
Who put that fan in? Upside down and stripped the screw...:pfff:
What is that material between the screw and the screwdriver? And also I had a prebuilt with a i7 4790 and GT 730. I brought the case to a local "pc-guy". He changed the case (and the PSU) and the GPU (now a gtx 960) and transferred other components (HDD,RAM etc.) into this new case. I requested him to put an extra fan on the front because this case has only 1 fan as stock. But that ********* forgot to do cable management and because of the cables that clog the space between HDD and GPU he put the intake fan on the top for better air circulation I guess.
Currently there is only one stock exhaust fan located in the back (you know, above the PCI-e slots in the case), and 3 intake fans one in the bottom (unfortunately unfiltered), one in the front (I managed to remove the dust filter btw) and the controversial top fan.
Once you get the screw situation figured out, flip that top one over. Blowing out.
