J javesike Sep 1, 2018 5 0 10 Sep 1, 2018 #1 Hey, I was just wondering on how to remove this ethernet box I had in my room 3 years ago. https://i.imgur.com/N7YapMl.jpg https://i.imgur.com/tFF4yLK.jpg
jsmithepa Polypheme Jun 14, 2014 13,091 264 60,840 Sep 1, 2018 #2 I suppose u can always just cut the cable and cover the hole with an appropriate sized blank plate. Upvote 0 Downvote
Wolfshadw Titan Moderator Aug 3, 2006 28,515 1,696 133,290 Sep 1, 2018 #3 Disconnect from the modem/router (source) and then clip the wires. -Wolf sends Upvote 0 Downvote
J javesike Sep 1, 2018 5 0 10 Sep 1, 2018 #4 The ethernet is no longer connected to this connection since I use cable now. is there a way to remove the wires without cutting them? Upvote 0 Downvote
jsmithepa Polypheme Jun 14, 2014 13,091 264 60,840 Sep 1, 2018 #5 javesike : The ethernet is no longer connected to this connection since I use cable now. is there a way to remove the wires without cutting them? OK, I guess I don't understand what is your end goal. What's wrong with cutting? Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,577 21,956 184,590 Sep 1, 2018 #8 javesike : ill cut it. thanks Is this in a residence that you personally own? What is the need for removing it? Upvote 0 Downvote
K Kasper Jorgensen Estimable Jun 10, 2017 3,080 1 3,960 Sep 1, 2018 #9 Look at sides or under the box, there is likely a few smal cuttings where you can insert a screwdriver to release the top. Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,577 21,956 184,590 Sep 1, 2018 #11 javesike : yes i own this residence USAFRet Then cut that silly thing off! Or screw it back to the wall and ignore it Or make it work, and use it. Upvote 0 Downvote
