[SOLVED] How to remove front panel from Sharkoon RV200 RTX PC case?
I can't find how to remove the front pannel and the side grates where the airflow comes from are in dire need of a good scrubbing.
I'm guessing you mean the REV 200? There's a finger pull cutout at the bottom of the case front panel. It may be tight if it's never been off before. Pull firmly but carefully. Here's a youtube video showing front panel removal. The video is fast timelapse. Change to 0.25 speed and advance to about 35 seconds to see front panel removal.
View: https://youtu.be/0QDLeRSlYDM
Thank you this is amazing, and yeah sorry I was just reading off the box and wasn't sure wether or not the rtx part was there because there were 2 different versions or not
