[SOLVED] How to remove hd audio cable from front io panel??
May 25, 2021
Having trouble removing the hd audio cable. Is it possible to just pull it out or is it soldered to the front panel pcb??
Most of the time it's removable from both sides, but the front panel usually has a specific connector where the number of pins may vary depending on the PCB design (sometimes the USB and audio pins are put together making it a larger connector).
