I have an old powersupply in my PC (the MS-Tech n550watt) and i switched to the Corsair 750w, problem is i cant get the mstech removed. It managed to remove every cable inside the case but theres 3 thick black cables and 3/4 shorter cables going from the power supply under the case and then a bit above reappearing inside the case going to the frontend of the case (where the on/off button is together with 1 usb 2.0 port and some audiojacks) and it seems to be stuck at that frontend and i cant seem to pull them out (without damaging anything i hope)
Any solution??
Any solution??
