How to remove Power Supply cables from Various Parts (Glued in?)
Cyannis
4
Greetings all! First and foremost I'd like to say that I'm pretty new to all of this so I deeply apologize if I provide lackluster information in OP. That being said, if you require additional information please let me know and I'll provide it.
Now to the real issue: About four or five years ago I bought a customized computer off of iBuypower. It's served me well so far, however my GPU has been running so hot that running most games results in my computer crashing. I came to the conclusion that the thermal paste in there must be too melted/dried out.
SO, when I went to remove the part, I simply could not pull the cable from the GPU. I tried this with several other parts in the computer and had the same lack of luck. Thinking I might just be not strong enough, I had a few other friends try with no result. Also, I did one time in the past have my cable removed from my frontal USB ports by a d00d from GeekSquad, but it looked like it took a significant amount of effort from a pretty well built guy. Is it possible the cables could have been sealed in with electro-conductive glue? And if so, is there any way to get them out aside from brute force? Or am I just doing it wrong? plz halp
Relevant parts list:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817190023 <- What I believe my Power Supply Unit is.
Case: NZXT Guardian 921 RB
GPU: HIS 6850 IceQX Turbo
Let me know if any sort of additional parts list is required, thank you all very much in advance
Edit: Made slightly more concise
There should be a clip on the top of them to remove them. It should take much force. As drtweak said, heating plastic up will make it more malleable. In an extreme case direct heat from a lighter may be user very briefly.
You don't specify what you are trying to remove. If its the heatsink, it may screwed on. Dryed thermal paste will not take too much to get off and I've never heard of a glued on sink. Mainly because plastic is hard to bond to and glue damages heat transfer.
A quick picture of what's to be removed could go a long way.
Ahh I see. Yeah I'll definitely try that soon.
Sorry, my post was a little bit ramble-y. What I'm specifically trying to remove are the psu cables to my gpu. I just decided to point out that none of the psu cables remove easily. I can wiggle them out slightly and then nothing.
So can a dryer except the heat is dispersed over a large area meaning you can over heat and damage other components. Dryers produce much more heat than a lighter.
Thank you all very much! I decided to play some games for a little bit to get my system nice and warm, shut down and unplugged my system, slipped some rubber gloves on and decided to not be afraid and give all the cables a good hard tug (And pressing the switches on applicable ones) and managed to get them off. All your feedback was very helpful and if I could pick everything as the solution, I would. 😛
