How to remove realtek audio driver
G
Guest
Guest
Hello,
I have acer aspire 4720z laptop.
when i am trying to install the proper drive it is showing failure
Pls help to fix this
Hello,
Hi
Have you tried this website already: http://support.acer-euro.com/drivers/notebook/as_4720.html
Try selecting a driver from the list, if this won't work you should try downloading the program Device Doctor on the following website: http://www.devicedoctor.com/device-doctor-download.php When you've installed the program press 'begin scan', and it will scan you're computer for the latest drivers, then check wich driver suits your sound system*.
Send me another reply if this doesn't works...
* -WARNING- Some drivers may still be appearing in the list once you have installed them.
