[SOLVED] how to remove the front panel from a kolink horizon rgb pc case
Sep 12, 2021
Hi guys,
Im a noob concerning hardware, but Im' trying to build a custom set up, i chose the kolink horizon rgb as case.
For the cooling system i chose watercooling, problem is the radiator doesn't fit on the top of the case, so I'd like to install it on the front case, but there are 3 pre installed fan there and I don't know how to remove the front panel. Searched all over the internet couldn't find a tutorial.
I'd be grateful if someone can help me. Thanks
how to remove the front panel from a kolink HORIZON pc case
great if this site told you how they took front off - https://basic-tutorials.com/kolink-...-tower-with-lots-of-glass-and-rgb-reviewed/3/
looking at 3rd photo it might just pull off from the bottom, might be a small gap at bottom of front you can pull out on. Mine is similar, it might be on tight if its not been off before. Can also check inside case and see if any tags holding it on.
Manual only available on a shareware site. boo. and from memory on these cases its just a sheet of paper anyway
