How to repair printer
Canvas-1
Commendable
Mar 11, 2016
My printer was damage it does not getting the printed papers and it was merged in to the system which is so much of problem for me and quality of the paper is so dull and some time the system was hanged it does not working properly on that path my project was stop if any bodies can suggest me to repair my printer
Ok, I don't know if you used google translate but here goes.
We need a printer model, otherwise we can only offer limited help.
1. Unplug / disconnect the printer.
2. If the mechanism that loads paper is jamming, remove all stuck pieces of paper.
3, If any rubber surfaces (rollers / drums / wheels) that are glazed over, you can clean them by gently rubbing a green scrubbing pad over them and washing them with alcohol; (see step #2 here http://www.redrivercatalog.com/infocenter/tips/how-to-clean-and-maintain-your-inkjet-printer.html)
Good luck
Good luck
