I'm using a Hyper 212 Evo as a cooler, and recently started to pursue Overclocking and it's benefits. My temperatures are quite high, and that makes it pretty hard to do it. I was advised to reseat my CPU cooler, and reapply thermal paste. The problem is, I've never actually installed a CPU cooler or applied Thermal Paste, because I had a lot of help when I first built my PC, and I really had no part in installing it. I'm not sure what compound was even used, although it could have been the stock paste. I have many questions. How hard is it is it to uninstall a CPU cooler and apply thermal paste, then hook it back up again? I researched a bit, but I'm still very worried and some of my doubts have not been clarified yet. How do I remove existing Thermal Paste safely? I heard 99% Rubbing Alcohol will do the deed, but I find this a bit risky. What happens if some of it accidentally gets in the socket, or trickles off the CPU unto the Motherboard? (see my sig for specs). More so, what is the exact methodology for applying Thermal Compounds? There are so many methods of doing so, which one should I use? And, my Hyper 212 Evo does come with it's own Thermal Paste. I'm concerned though, because it is probably conductive, and that carries a large risk factor when applying, right? I've been thinking about getting some Arctic Mx-4. Is that non-conductive and won't be an issue if some gets on my Motherboard capacitors, etc? Also, how should I get all this done? Is it complicated? This is an observation on my part, but my Hyper 212 Evo is raised a bit to allow Ram clearance. Could that complicate anything???
These are just my general concerns, but I'm still not certain if any of this is needed. Only one person recommended I check out my CPU cooler.
However, I did check my cooler today and it is secure and looks like it is seated properly. I cleared a big caking of dust out of my I/O holes, and I do notice some better airflow because of that, but I'm still running rather hot considering I'm using a reputable cooler and am currently on stock. Even on stock, I am idling 31c from the hottest core, but in the Bios it is reporting "CPU Temperature" as 20-23c.
In Prime95 blend, after 23 minutes, the temperature is in the mid 60s, but a few minutes earlier it was even in the 70s, still on stock, and my voltage really isn't high at all, 1.220 on stock (3.9ghz turbo). I would really love some help and guidance, I'm once again at a loss.
