Question How to see the pump speed and temps of an AIO GPU?
redteamrocks
9
4
10,515
Hello all,
I'm having trouble finding any useful info on this. Is there a program out there that I can use to see the pump RPM and liquid temps of a Graphics card with an AIO cooler?
The card I'm using is the MSI 1080 Seahawk.
Thanks!
You could try and use HWMonitor or HWInfo but the AIO's pump, to my knowledge, is managed by the GPU alone. What does MSI's Afterburner show you?
The AIO reminds me of the H105 from Corsair and if that was the sort of design Asetek used, then you won't be able to monitor the fluid's temps. Cards from back in the day with custom watercooling needed thermal probes at inlet and outlet to monitor fluid temps, as far as I can recall.
Reactions: redteamrocks
Got it, thanks for the info.
HWInfo and Afterburner don't show me info pertaining to pump speed or liquid temps. The only info I can see is GPU temp and fan speed.
