[SOLVED] How to select suitable size Air Cooler for Gigabyte C200G and MSI B450 Tomahawk MB.
UsamaJutt031379
15
I don't know how to calculate the size. I want to know that if Antec A400 Air Cooler will fit in my Gigabyte C200G case with MSI B450 Tomahawk Motherboard with XPG Gammix D30 16GB Ram.
OR
If anybody can tell me how to calculate.
What is your processor?
Noctua maintains a large database for motherboard and cpu compatibility for their coolers.
There is also a cpu suitability table:
https://ncc.noctua.at/cpus
Here are the results for a R5-3600 as an example.
The A400 is a decent cooler with a 120mm fan.
A slightly stronger cooler might be the noctua NH-U12s redux
