how to set fan speed asus sabertooth z77
misfitkid86
709
hey all, i want to plug my three pwm 4-pin fans in to the motherboard for control but i seem to be lost as to how to set them in the bios! i see the spot you can change profile to manual, silent, etc but is that it? can i get more control!? i'd like to run my fans at or around 1000 rpm (they're corsair sp120 quiet's) so what should i do? also speedfan doesn't seem to be compatible unless i'm missing something.....
You can set fan speeds VIA the Asus Suite II, under Thermal Radar you can adjust settings for each fan manually. Be sure to apply for each fan you change. I used this for turning off my 80mm fans.
ok that's what i was assuming but when i checked ai suite 2 i couldn't change anything, do i just set fans in the bios to manual or am i missing something? thanks!
