How to set LG Gram's num lock key to automatically be ON when it boots up?
John Dohe
64
Does anyone know how to set the num lock in my LG Gram
to automatically be on when it boots up?
My LG Gram:
Device name xxx
Full device name xxx
Processor Intel(R) Core(TM) i7-1065G7 CPU @ 1.30GHz 1.50 GHz
Installed RAM 40.0 GB (39.7 GB usable)
Device ID 52D5542C-5CEC-4C66-B175-8E484BE67AA5
Product ID 00330-75074-33277-AAOEM
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Edition Windows 10 Pro
Version 22H2
Installed on ‎12/‎7/‎2019
OS build 19045.3086
Experience Windows Feature Experience Pack 1000.19041.1000.0
Is there a BIOS setting to set the the num lock in my LG Gram
Thanks!
As posted above, check BIOS first.
Failing that then there may be other ways.
Some involve Registry Editing but that should be a last resort.
Very likely there will be some utility app or even a simple script that can be launched at start up to set up Num Lock.
Is the requirement to simply enable num lock or is the requirement to toggle num lock on/off?
