Just like I said in the title, I was wondering if there was a way to setup devolo power line adapters in a way in which a wireless device, such as a phone, will connect to the devolo adapter, and when the signal gets weaker (not when it breaks) then connect to the other access point if the signal is better. At the moment I have the main access point in the kitchen, (net gear router), with one devolo plugged into that (2 port 500Mbps non-wifi version), along with the same device in my bedroom, and a similar device however the 'wifi' version in the living room. the one in the living room has the SSID: devolo-f40......
So my question is, how can I configure the wireless devolo to have the same SSID, and password as the wifi, and so that any devices connected to either device will switch seamlessly between them to whichever has the best signal strength
Thanks In advance
Thanks In advance
