[SOLVED] How to solve Condenser mic Buzzing Sound
Himanshu Panchal
86
I'm using Parrot OS as my main OS and I'm facing problem regarding my microphone
I already enabled Noise Cancellation in it and it is now not caching any background noises but my make making continues buzzing or sound .
Please any one help me to fix this.
This is the last line in my /etc/pulse/default.pa file below:
"load-module module-echo-cancel source_name=noechosource sink_name=noechosink
Likely a ground loop somewhere in the mic circuit, possibly the mic itself. No amount of playing around with drivers or config files will fix this.
yaa I to figured this out by changing ports I to think its something outside or my XLR cable is making some issue.
What could we the best solution for this?
Should I purchase Phantom Power?
Or I go for new Microphone?
I.m currently using BM 800 the cheapest Mic in the market i guess.
