Hi
I would like to know if there is anything i can do with my PC setup to speed up extraction time for compressed rar/zip files.
I have two 2TB Samsung 5400 rpm drives one of them has a 500 gb partition (C) for the OS (Windows 7 64 bits) and (F) for storage, the other drive (E) is 2TB of storage, both AHCI enabled.
Memory is kingston 4gb DDR3 at 1600hz dual channel
Cristal Disk Mark rates C/F and E drives at about 100MB/s read and write speeds.
If a copy a file from C/F to E the speed I get is 60MB/s which I am ok with it.
However, if I unpack anything from C/F to E the maximum speed I get is 10 MB/s
My motherboard is an ASUS M4A785 TD V EVO with sata II ports.
CPU is AMD Phenom II 4 cores 2.5hz, 65 watts
I have tried winwar and 7zip, both with similar results.
The files I need to decompress range from 10 gb to 50 gb so uncompressing any of them takes from 30 minutes to 1.5 hours
Given de Cristal Disk Mark rate of 100MB/s and the copying speed of 60MB/s, uncompressing at 10MB/s doesn't really sounds good to me, any ideas?
Thank you
Thank you
