How to speed up laptop.
sulfonicwharf
70
My Windows 8.1 laptop is very slow.
Is there a way i can speed it up for the lowest price possible.
SPECS:
Intel I5 3230M
4GB Ram
Windows 8.1
My boot time is around 3 minutes
It is a Samsung ATIV Book 2
First do what USAFRet, startup programs are known to be the cause for many laptops to slow down as time goes on.
Second, see what programs you have in your control panel and uninstall any programs you don't need.
Third, check you c and d drives to see if you see any files that shouldn't be there. For the c drive make sure you check both the program files folder. For example, many times when you uninstall a program, it leaves the file of that program in the c drive and keeps a reference there. The only way you will know it is there is by going there and checking the contents of the folder.
Fourth, backup personal data on an external storage like a hdd. Then delete it off you hdd. This will allow more space for the system to use as page files if it needs it.
Fifth, use software that is not resource intensive such as using firefox instead of chrome as a browser.
Finally if all this doesn't help then start thinking about upgrading the hardware. For example you could upgrade the ram to 8 but make sure it is the same speed as the manufactures and is compatible with your laptop. Also swapping the hdd for an ssd helps but these are only good if you don't need much storage.
can you please check this
https://docs.google.com/document/d/1rId3TRySjbGfFXxl-nyQRkGmQjZteVagLHgeYLV6FOQ/edit
