How to split the system onto two drives
okrobie
141
7
18,695
Hi, I'm building a computer using a SSD For the boot/system drive and a large sata drive for storage. Using Windows 10, I want to put the c:\user folder on the sata drive. How do I do that? Thanks
Changing the location of the whole /Users/ folder is contraindicated.
Some things WILL choke on this.
http://www.zdnet.com/dont-move-your-windows-user-profiles-folder-to-another-drive-7000022142/
Move the location of the individual Libraries instead. Not the whole thing.
Read these for how to manage space between the SSD and your other drive:
Win 7 & 8: http://www.tomshardware.com/faq/id-1834397/ssd-redirecting-static-files.html
Win 8.1 & 10: http://www.tomshardware.com/faq/id-2024314/windows-redirecting-folders-drives.html
Changing the location of the documents etc. is the important bit. I'm 99% sure this is all you have to do.
There is a method in here (following a quick google) that tells you how to do it 'clean' and post installation.
https://www.tenforums.com/tutorials/1964-move-users-folder-location-windows-10-a.html
Good point, the simple folder move is better. There is a means of recreating those folders in the default locations (blank of course) should something go wrong.
