[SOLVED] how to stop CDRom Drive from work after "sleep mode"
sonah
127
Hi
How to stop CD-Rom Drive from start working in MB BIOS
Because every time I start my Windows10 PC from "Sleep Mode" the CD-Rom Drive make Noise and i don't use it alot, I only use it 1 or 2 times in a year only
my motherboard Gigabyte Z77X-UD4H
I use Windows10
sonah
127
After i Restarting PC I still Hear the Noisy Startup of the old CD-Rom Drive
I will try entering Bois to Disable it there..
If not work I will remove the power cord from CD-Rom Drive
Gerald6049
743
80
590
26
Hi
I use Windows10
Try to disable the DVD/CD ROM drives from Device Manager.
sonah
127
I disabled the CD-Rom in Device Manager and i still get the Start Noise when I wake up PC from "Sleep Mode" :(
I will try to reboot PC
sonah
127
