How to stop feedback and playback from mic into headset/speakers using voicemeeter banana
bromandude18
I’m using voicemeeter banana to play audio through two different sources (my headset and my monitor’s speakers) but when I go to use my mic my voice and all the audio that the mic picks up is played through both sets of speakers. Also there’s loud feedback anytime my mic isn’t muted. If anyone could help, it would be greatly appreciated.
The only way you can keep it from playing what you record through the mic in both the headset and the speakers would be to turn off the speakers before you say anything into the mic, and then turn them back on. I know of no way to just shut off the one, when you have intentionally set them up to stay on. You can always set it up to only be heard through the headset and not the speakers, that would resolve the problem.
Perhaps you can set up a shortcut key to hit to turn on the speakers and turn them off. Allowing for a quick change over.
The feedback would be from the same issue, having the speakers on as well and it sounds like the volume may be up high, which would add to the feedback.
