J jaf1793 Commendable Oct 3, 2016 4 0 1,510 Oct 3, 2016 #1 A black box comes up frequently that has a message "Auto-Adjustment in Progress...". I have Windows and the monitor is an HP monitor.
Solution Phillip Corcoran Oct 4, 2016 If that feature can be disabled, it will be in the monitor's on-screen menu system using the buttons on the monitor.
Phillip Corcoran Titan Moderator Sep 7, 2013 26,104 912 120,140 Oct 4, 2016 Solution #2 If that feature can be disabled, it will be in the monitor's on-screen menu system using the buttons on the monitor. Upvote 0 Downvote Solution
J jaf1793 Commendable Oct 3, 2016 4 0 1,510 Oct 7, 2016 #3 Phillip Corcoran : If that feature can be disabled, it will be in the monitor's on-screen menu system using the buttons on the monitor. Upvote 0 Downvote
J jaf1793 Commendable Oct 3, 2016 4 0 1,510 Oct 7, 2016 #4 There are 5 buttons on this monitor. When I push on them only one of them opens up - "Power Button Lockout" - and that has not solved the problem. Upvote 0 Downvote
