How to stress test multi GPUs without SLI?
warhammer23
71
I can't make SLI work on my system and I want to test a power supply. I have 2x 9800gx2 and want to put full load on them.
So I was wondering if there is a way to put that Quad SLI setup in full load on all GPUs without the SLI been active.
Furmark? Kombustor? Etc
Thank you.
Considering a 9800x2 will be running at close to 200 watts or power, even having one of them fully active during testing should show you if the power supply is good or not.
Aha I see, yeah I can hook each gpu to another monitor. Will try that.
Just to load test the PSU. It's more fun testing than empirical data but wanted to see first if it can be done.
Thanks.
Latest posts
