R rudrat133 Sep 7, 2018 1 0 10 Sep 7, 2018 #1 see i bhought a headset for my laptop . which had two cables audio and mic for which i use splitter(2female and 1 male) now how to switch my microphone from in-built to headset one?
Solution hang-the-9 Sep 7, 2018 When you plug in the headset it should set the headset mic as default. If not you can go to the audio manager and select which mic to use as default.
hang-the-9 Titan Mar 25, 2010 60,368 1,081 152,940 Sep 7, 2018 Solution #2 When you plug in the headset it should set the headset mic as default. If not you can go to the audio manager and select which mic to use as default. Upvote 0 Downvote Solution
