How do i tell if a CPU fan or a case fan is PWM vs voltage controlled? Is it just whether it has a 3 pin plug vs a 4-pin? Are all 4-pin fans PWM?
I ask because I installed the stock Wraith Stealth cooler for a Ryzen 3 chip, and I can't find specs for it anywhere, and don't know if it's PWM or not. It's set to PWM in the BIOS now, but it's running at a high RPM even though my CPU temps are cool. So wondering if it's not actually PWM.
