I just installed a corsair hydro h50 water cooling heat sink on a i7-4790K.
It makes the CPU much cooler than the stock intel heat sink, but the temp still reaches more than 85 degree C when I run prime95 at 4200Mhz (I started low and gradually increase the multiplier until 85 degree). My mobo defaults to 4300Mhz, so I'm actually underclocking the CPU.
I wonder if maybe I didn't put the thermal paste on correctly. The idle temperature is about 33. Ambient is 25.
Is there a guideline on what temperature I should expect to see given the heat sink and clock speed, load, etc?
